remote panel connection
I try to run the RemotePanelMethods examples in one computer, that means I used one computer as both server and client. The LabVIEW version I am using is Professional 7.1. I don't think there is any mistake in my webserver configuration and IP address settings. But the connection just didn't work. I open the REMOTE PANEL CONNECTION MANAGER, it shows the maximum client number is zero (it is supposed to be at least one license for this version). The www.log file is empty.
Can anyone give some suggestions?
The error message for possible reasons is shown as follows:
LabVIEW:  Serial port receive buffer overflow.
LabVIEW:  The network connection was refused by the server.
Thanks in advance.
Jane
Message 1 of 9
(5,131 Views)
Hello Jane:
Could you please go to "Start"->"Programs"->"National Instruments"->"NI License Manager"
Expand the "LabVIEW", then expand the "Version 7.1".  Then click the "RemotePanelConnection".
Please tell me what you see in "Total Licenses", "License File Expiration", etc.
Message 2 of 9
(5,120 Views)
Hello Debonair,
Here is what I seen for the licensing information of Remote Panel Connection:
Product Name            RemotePanelConnection
Associated Software   LabVIEW
Software Version
Message 3 of 9
(5,106 Views)
Hello Debonair,
Software Version
Message 4 of 9
(5,106 Views)
Hello Debonair,
Software Version
Message 5 of 9
(5,106 Views)
Hello Debonair,
Software Version
Message 6 of 9
(5,106 Views)
Hello Debonair, Thanks for your response.
Here is what I see for the licensing information of Remote Panel Connection:
Software Version        7.1
License File Expiration Never
Status                          For evaluation only. Activation is requested for the licensed version
Note                            The license server must be active in order to use this product
Total Licenses              1(5 if professional development system)
(I am using professional development system)
That's all. One thing I feel strange is I can use Web Publishing Tool to view and control the panel, but for the RemotePanelMethods examples (you can find them in LabVIEW examples library) I just couldn't make it work.
Look forward to hearing from you soon.
Jane
Message 7 of 9
(5,106 Views)
Hello Jane:
I just found a note from a text from the instructions from the example:
     NOTE:This must be done in another LabVIEW of the same version since a remote panel connection
     cannot be made from a LabVIEW to itself.
Message 8 of 9
(5,103 Views)
Brilliant! Now I can give up trying again and again before I get another computer to communicate with it.
Thank you very much!
Message 9 of 9
(5,100 Views)
