remote front panel
Hi, I'm new to labview. Now i have a program which is running in server mode. The application also build for the remote front panel. So my question is whether the client use the remote front panel to download the require file from the server to client computer under different 2 networks ? Thank you.
Message 1 of 9
(4,422 Views)
Remote front panel is for monitoring or controlling the front panel of vi in the browser.
Frequent snapshots of the vi can also be sent to the browser[Monitoring]
Please explain clearly.VI running in server mode means??? usingTCP???
File you want to download means, are you asking like FTP??
Also two different networks means?? not in LAN??
Aarthi
Message 2 of 9
(4,409 Views)
On the server make your application as a web service, stream your file on the network. On the client machines, make simple web page from which use can save file from server machine.
2 different network, It means there are 2 servers and if they communicate each other, then you can share remote panel from one server and clients of other server can access it.
Message 3 of 9
(4,398 Views)
My main vi is just displaying data in graph where data are from MODBUS module which using LAN port. The main vi will gain all the data and generate a file (such as Excel file) after clicked a button. This file is generated at the server computer. With this function, i also published the front panel into web which is remote front panel. So now i want to generate the excel file by using another computer (client computer) access through the remote front panel to generate the file and the file is save to the client computer. The two different networks i mean was the server computer and the client computer is not connected under same network. So i want ask that whether remote front panel can do this function or not? If yes, then how to do it? Sorry that let you confuse
Message 4 of 9
(4,385 Views)
but my client server is using web browser such as internet explorer to browse the remote front panel. Can it possible to do that with create 2 server ?
Message 5 of 9
(4,384 Views)
Hi Puneet,
  I have understood the web service part, but didnt try it anymore, let me give a try and come back.
Can you please explain more about Remote front panel between two servers?
Aarthi
Message 6 of 9
(4,382 Views)
You must have client and server in same network or internet, then only client can access remote panel.
Follow link: http://zone.ni.com/devzone/cda/tut/p/id/4791
Message 7 of 9
(4,358 Views)
Hi Puneet
So if how about the client and server are not in the same network or internet, will the client can download file through the remote front panel ?
Message 8 of 9
(4,345 Views)
It is not possible when they are not in same network.Try to do port forwarding from router.
Also as puneet said, file transfer can be done with
streaming in web service
Aarthi
Message 9 of 9
(4,309 Views)
