remote front panel,help?
hi i've problem to remote front panel in labview 8.6. i've trt to make it then it's succes but i can't get connected with the front panel labview. tell me why and how to setting if i want to publish front panel ?
tanx
Message 1 of 19
(4,760 Views)
Marp,
You really need to learn to put more detail into your questions if you want to get any help.  And also put your questions in a clearer form of English.
What does "i've trt to make it then it's succes but i can't get connected with the front panel labview" mean?  Do you have a Pop Tart?  It's successful but it can't connect?
Are you getting any error messages when you have a problem?  If so, what message or are there any error numbers?
Are you using Web published front panels?  Does the remote PC have the LabVIEW runtime engine installed?
Message 2 of 19
(4,748 Views)
yes i use web pubish tool and it's have runtime engine.
why the font panel loaded so long?
how to setting web server configuration at labview 8.6 ?
Message Edited by marp84 on 07-28-2009 10:45 PM
Message 3 of 19
(4,744 Views)
So you can connect to the front panel with the browser.  There is no error message.  It just takes longer than you think it should.  Is that what you are saying?  If so, how long does it take?
How much stuff do you have on the front panel?  If you have a lot of controls, indicators, graphs, tabs, ... it may take longer to download the front panel than a simpler VI.
Message 4 of 19
(4,738 Views)
yes i want to remote front panel through web use web publish.
but why when i want to view and remote it with another pc it's says page not found.
can you help me to solve this problem.
tanx
Message 5 of 19
(4,719 Views)
See if this message thread helps.  Try turning off the Windows firewall on the PC running the VI, it may be blocking web server requests.
Message 6 of 19
(4,710 Views)
i've this message error from web,what's wrong?
Message 7 of 19
(4,699 Views)
I would try loading the page in Internet Explorer.
I don't have a lot of confidence that Firefox handles high end things like ActiveX, Java, scripts, all that well.
Message 8 of 19
(4,684 Views)
why it's can't open at firefox or ie?
Message 9 of 19
(4,672 Views)
I have no idea.
Can you view the webpage on an instance of Internet Explorer or Firefox on the PC that is actually running the VI?
All I can do is recommend that you search the NI website and the forums for terms like web publishing, remote panels,  ...  There are numerous messages and knowledge base articles about this topic.  Read through them and perhaps one of them will have the tidbit of information you will need to get this working.
Message 10 of 19
(4,665 Views)
