11-09-2011 11:57 AM
hello
i want to control the air condioni AC with a relay circuit to switch it on and off by WSN (wireless sensor network), i want to send a digital output to the node and then from the node to digital to analog conversion circuit then te analog output to the switch circuit which will be a relay based, so is this possible to do or not ?
11-10-2011 03:48 PM - edited 11-10-2011 03:57 PM
Hi duaa,
Could you please be a little more specific about what you want the WSN node to do? From what you wrote it seems like you want to do digital input and digital output from the node, which is possible. Is understanding correct?
Matt
11-10-2011 03:55 PM
11-10-2011 04:03 PM
If you want to use digital output wirelessly I would reccomend using WLS instead of WSN nodes. WSN nodes are more for sampling data, than for controlling things.
Here is a link to WLS-9163: http://sine.ni.com/nips/cds/view/p/lang/en/nid/205688
Matt
11-10-2011 07:42 PM
