relation between frequency and sample rate
Hi
I am trying to generate voltage and also measure some voltage in the same program. I am confused about the frequency and sample rate. I have tried to generate a 1000Hz frequency with amplitude of 1 volt. With a sample rate of 5000 when i tried to check in an oscilloscope, the frequency is different, i mean it shows 2000Hz frequency and with a sample rate of 10000 only it shows the correct frequency. I also want to know what shud be the input sample rate. I notice that the signal generated is more or less correct but not stable. What shout be my input and output sample rate for 1KHz frequency?
(3,970 Views)
Not sure exactly what is your problem.  If you are able to post some code, i might be able to help.
Craig
LabVIEW 2012
(3,964 Views)
Hi Amber,
The theoretical limit to reproduce a frequency is given by the Nyquist theorem.  There are many articles about this on the web.  Here are a few brief sections from our high speed digitizer manuals:
Nyquist Theorem
http://zone.ni.com/reference/en-XX/help/370592E-01/digitizers/nyquist_theorem/
Aliasing
http://zone.ni.com/reference/en-XX/help/370592E-01/digitizers/aliasing/
Although the theorem says you can reproduce the frequency of a 1000 Hz sine wave at 2000 Hz, the shape will not be maintained. It will look like a triangle wave at best.  When trying to generate an output frequency of 1kHz, a 10kHz generation rate gives you 10 samples to represent each cycle of your sine wave, which starts to look ok.  In general, try to generate at at least 8-10 times the maximum frequency in your signal and higher if you aren't limited by your hardware.  I hope this helps.
John Bongaarts
(3,926 Views)
