reinitialize problem
Hello, I'm using an "Invoke Node" of my Vi,concretely  the method "Reinitialize all to default"  for reinitializing all my indicators and my waveforms, but some of them don't initialize. What can I do?
Thank you very much.
Luz
(3,215 Views)
Please note that "Reinitialize all to default" only sets Values to default, not other indicator properties.
For example, if you previously set a scale to logarithmic view, this won't be changed.
Is it this the problem?
Paolo
Paolo
(3,208 Views)
This is one of the problems, but I have problems with values too. For example, plotting my waveforms. When I run my program, signal seems to be initializate, but I have previous value too. What can I do?
(3,203 Views)
Luz,
what do you mean with " but I have previous value too". It would be easier if you could implement a simple/small VI ( maybe with the waveforms you are reference to ) and attach it explaining which is the behaviour and the exepected one.
crisR
(3,188 Views)
