regular expression for finding anything which isn't a defined sequence
Hi there,
Just having a little trouble with a regular expression. I have an input string and I want to find anything that isn't that string, so
Input = Hello
Match = Hello
Match? = False
Input = Hello1
Match = Hello
Match? = False
Input = Hello
Match = Goodbye
Match? = True
As I thought I understood it, to enter it as a regular epression in the Match Regular Expression.vi would be ~(Hello).
As I also understand it, I can't achieve this by using match pattern.
Perhaps you good folks can correct me. Thanks!
Message 1 of 14
(3,934 Views)
do you mean this
Message 2 of 14
(3,907 Views)
Yes that's functionally the same although I'm trying to work with an existing API and so was looking for a single regular expression that would do the same ideally so I don't have to change the interface to include the case.
Message 3 of 14
(3,894 Views)
so does your problem solve with that vi or you need some thing more ?
Message 4 of 14
(3,889 Views)
@rik_aspinall wrote:
Hi there,
Input = Hello
Match = Hello
Match? = False
Input = Hello1
Match = Hello
Match? = False
Input = Hello
Match = Goodbye
Match? = True
If I understand you want Match? to be true if the input string doesn't contain Hello?
Ben64
Message 5 of 14
(3,885 Views)
Folks, perhaps I should add more info - I'm trying to achieve this only by entering somethining into the regular expression field, and not by adding code. Thanks, Rik
Message 6 of 14
(3,861 Views)
It would then be very helpfull to see what the actual code looks like. How is the Match? value generated? You're talking about defined sequence, can you show us what typical sequence looks like? And what are the expected values returned from each output of the Matched Pattern vi?
Ben64
Message 7 of 14
(3,853 Views)
It's pretty much like the snippet you posted, except that
1) to detect a match I check if the count returned is equal to -1 rather than use the match string being empty.
2) The actual text I'm searching for is a vi name that is printed in an error log, so as I described above if I were searching for "~(Hello.vi)" as a match, "Hello.vi" would return a false while "SayHello.vi" would return a true or even "PrintHello.vi.vi" would return a true. That is, I'm looking for anything that isn't exactly the name of the .vi string. Perhaps we could think of it like stripping any records containing "Hello.vi" from out of the log because they are trivial.
Message 8 of 14
(3,835 Views)
this vi help you to find vi in error comment
Message 9 of 14
(3,823 Views)
Rik,
If my understanding of your requirement of the test is correct, are you just looking to see if the two strings are different?
If so, why don't you just use not_equals?
It doesn't have to have numeric inputs.
See http://zone.ni.com/reference/en-XX/help/371361J-01/lvconcepts/comparison_funcs
http://zone.ni.com/reference/en-XX/help/371361J-01/lvhowto/string_comparison/
Rod
Message 10 of 14
(3,810 Views)
