registerkarte
Iam using registerkarte in my VI.on this registerkart iam using 4 pages.But if I click on one page it should ask for password.Iam having password subvi,but i dont know how and where to use this subvi.pls tell me how can i do this.
(2,433 Views)
Hi
There are different ways to solve your problem, depending on the functionality you want to program.
One way could be:
Use a producer/consumer-pattern. In the event-structure, add the value changed-event of the tab-control. Produce a queue-entry in this event-case.
In the according consumer-case you can place your password sub-vi.
You also could place the password sub-vi in the event-case, but, in this case, be aware that all other events are blocked, as long as your password sub-vi is running.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,426 Views)
