register for counting
Hi !
I want to count the number of times my application runs.Each time the application is run ,the count is incremented.How can i create such a register to store the value in my program.
Regards
DeWalker.,
(3,025 Views)
Hi DeWalker,
in this case you have to store the counter value in an ini file or in the registry. Read the old value at the beginning of your program and write it before closing.
Mike
(3,014 Views)
Hi!
I have saved the value in a txt file and write to it before exiting my program.Are there specialised blocks for saving values to ini or registery???
(3,010 Views)
Hi DeWalker,
a txt file should also be ok for a test. There is a libraray for ini files in the File I/O palette and a library for the registry in the connectivity palette.
Mike
(3,008 Views)
