regexp
hello,
i use a regexp to format entries
for now i use [^\w]  to detect when it is not a word but i would like not to detect   back " <--"  and del ?
regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(2,765 Views)
Hi Tinnitus,
From your question it seems you are trying to ignore all word characters as well as backspace and delete characters.
You should be able to achieve this with the following regular expression: [^\w\x08\x7F]
\x08 and \x7F represent the ASCII code in hex format for backspace and delete respectively.
Hope this helps!
Stephen C
(2,744 Views)
