regarding DPO 4000 series
Hi iam using the DPO 4000 from tektronics ..with labview8.0
I am implmenting an application where i should be setting the falling level for the triggering ...
I want to know how can i set the oscilloscope using the VI's ,by which i can make it wait ,untill the trigger level ( i need falling edge trigger) is reached ...??
And when once the above is attained ,is there any specific VI by which i can capture the screen shot of DPO 4000 as an .bmp or .jpg and transfer it to my pc for saving it ??
Shake.
(3,456 Views)
Have you looked at the example called tkdpo4k Edge Triggered Acquisition Waveform Example? It uses a configure Edge Trigger function that you can set the slope and voltage level of the trigger.
For a screen capture, you've presumably already have the information on the LabVIEW front panel so the simplest thing is to just print that out. I know the driver has no function for a screen capture nor do I know if the scope has a function like that. If you look through the scope's manual, see if such a function exists. If it does, then you can issue that command by doing a VISA Write and then use a VISA Read to get the data.
(3,447 Views)
Thanks dennis..
Iam facing a new problem with the DPO4000 ...
Ihave comnnected the device thr usb .. and when i opened the "OPEN CHOICE DEsktop" for the DPO4000 .. and after using it ..i closed it ..
then when i try to run my labview 8.5 application that uses the DPO4000 Vi's iam getting an error code like -1089xxxxxx ...
I doubt some where the usb is held and its not getting released ..so that my Vi uses it ..but i didnt find any solution ..even i reconnected the usb connection back in, hoping that works , but unfortunatley it did not ..
can u suggest me with this ???
(3,426 Views)
I'm not familiar with the Open Choice software but if you could provide the exact error code, that might help in determining what might be wrong.
(3,424 Views)
thanks,
dennis
I have resolved the issue.
Anwar
(3,414 Views)
hi ...
 iam using the SAVE command to save the screenshot on to a flashdrive connected to the DPO..Now i want to get the .bmp file to my PC ..
Is there any specific VISA command that can do it for DPO4000 series...
I have referred the manual .. and i founf FILESYSTEM:READFILE "E:xxxxxx" which can read the data filess like .txt ..but how can i use this to read a .bmp file .....
Need suggestions
Anwar.
(3,402 Views)
