refnum of an application
How can I do to get the names of all the applications running and the Refnum of the Vis ?
The purpose is to not re-open an application running and close those that I no more need.
Does the lvwutil32 DLL exist for LV 8.5 ?
Bruno.
(2,987 Views)
One suggestion would be setting the configuration just opposite as mentioned here
Just set 'allowmultipleinstances=FALSE'
(2,972 Views)
Kernel32.dll has a function called "createtoolhelpsnapshot" which can be used to get the list of all the applicaitons shown in "task manager".  Refer this page and try out this dll.
Refnum of the Vis
not sure whether refnums of all the vi's can be obtained [some may be called dynamically].  Using the application instance try getting the vi list.
Post back for queries.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(2,963 Views)
Thanks for your responses.
It is not exactly want I want but it helps me.
I've found an Vi example one day that displays all the running applications exactly like the TaskManager, but I don't remenber where...
Do you have such examples ?
Bruno.
(2,952 Views)
