03-11-2017 03:16 AM
hello everyone,
i am reading and saving 6 sensor output from an instrument using labview. rs485 communication is using here. normally its saving 2 samples per second in to excel file. i need to reduce this no of data saving. eg: instead of one reading per second i want to save one reading per minute or 10 minutes etc..so for getting that what logic i need to use or any special function is available in labview?
please help
Solved! Go to Solution.
03-11-2017 04:52 AM
I would use the Elasped Time function and a case structure.
03-11-2017 06:13 AM
@Krishna_kp wrote:
hello everyone,
please help
If you have a while loop, and you want to execute a certain task at a certain frequency, I would just use a modulo devision:
