redo in a for-loop (or while-loop)
Hi
The attached VI waits for the "trigger" button to be pressed and then displays the current trial state.  However, if the redo button is also pressed then I would like it to decrement the index by one and then display the trial state.
My actual use-case is the following.
After Labview receive a trigger from external hardware start collecting analog data. It monitors this data and triggers another piece of hardware if the analog data reaches a threshold. This threshold can have different values for each trial.  However, the operator might want to be able to redo a trial (if the trigger is sent to early because of noise or the threshold isn't reached as expected).
I am not sure how to set this up.  Any ideas would be greatly appreciated.
Azim
(3,412 Views)
I think you have better to take State Machine Pattern (which means using of while loop) for redo function.
(3,409 Views)
Since you don't know the total number of iterations (depends on the # of redos!), you need a while loop.
Here's a quick draft how you could do it using an event structure. Modify as needed. 😉
(3,398 Views)
