recursion with reentrant vi's
Hi tbd,
when posting I had some issues hence the numerous attachments....
I can see why your first example doesn't work, first you open a reference to the same vi (not only in name, but also in memory) thought truly recursive, this will fail.
The second method is new to me, I'll have a look at it
Ton
My LabVIEW Ideas
Message 11 of 13
(781 Views)
Hey TonP,
      Ran into a rather annoying limitation of this recursive technique (at least in 7.1) .  It works if "A" calls itself dynamically.  But if B is a [re-entrant] subVI of A, and B calls A - then there's a problem (Error 1042.)
Cheers.
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
Message 12 of 13
(764 Views)
Hi TBD,
strange could you contact me at LAVA? I'm known as tcplomp
Ton
My LabVIEW Ideas
Message 13 of 13
(760 Views)
