recording with the mic met 4822 error
I write the attached vi, the purpose is to make six mic recording in parallel.
Looks like it can't run in parallel and sometimes met the error code 4822.
could someone give some suggestion on this?
(2,182 Views)
Accepted by topic author James985
You cannot run them in parallel because those APIs are non-reentrant.
You can make a copy of those APIs to your project folder, then edit the VI settings to be shared clone.
Santhosh
Soliton Technologies
(2,152 Views)
Thanks Santo. This works.
(2,147 Views)
Hi Santo,
When I change the vi to reentrant, sometimes it will report error 4823
(2,106 Views)
