record waveform wav file
I am trying to record a waveform in a wav file. If i play the waveform with the VI  Labview the quality of the sound is ok but when i try to make the wav file the quality is not ok. I attached the file i want to save as a wav file and the VI i programmed. Thanks a lot!
Another question: There is any way to stop playing the waveform (or stop the program) when it enters into the "Play Waveform.vi"?
Thank you very much
Javier
(2,868 Views)
I forgot before... i am using labview 8.0 so if you send me a VI, could you please send it to me saved in this version? Thanks
(2,865 Views)
Thank u, it's not necessary to reply me i get the solution.
cheers
JAvi
(2,859 Views)
