reconnection of network stream
Hi, I am enjoying the network stream between two applications.
I opened the good example of host and target embeded in LabVIEW.
Do you know how to reconnect the network stream in the other if one of two application was quitted by mistake?
In my case, the other should be relaunched to get a normal network stream reference.
When I tried to create it again, I met the error message.
LabVIEW:  An endpoint with the same name already exists.
How can I remove the end point for reconnection?
Message 1 of 1
(2,849 Views)
