realmatrix Pb
I am using the realmatrix objet to store a table o couple of parametre
The number of Row is control By a parmater Nx  throuhgh a propertie node
When I change Nx  , I make the length of the matrix very long even if is full of Zero
Is it a known bug of LV 8.5
When I make a unitary test with this object I dont't get this Pb
When Using the some object in another cluster It works..
Message 1 of 8
(3,065 Views)
has somebody met the same PB?
Message 2 of 8
(3,056 Views)
Hi tvinchon,
what is your goal in changing the pixel width of the array indicator?
What's the reason to change the look of the indicator when the values represented don't change?
Message 3 of 8
(3,049 Views)
What I asked to change via thje properties node is the number of row
but what happens in the same type is a enrmous change of the visualized area (- even if after columns two ther is only zeroes
If you look at the word document   joined to the prevsious thread , , you will see what happens
Message 4 of 8
(3,044 Views)
Hi tvinchon,
ever tried to use other properties like "number of rows" and "number of columns" instead of indicator size?
Message 5 of 8
(3,041 Views)
Hi GerdW
I am using propertie node  nb of rows and it affect also the width  (either I don't want it )
The size is not programtically controlable  (read only property node at least in LV 8.5)  but after the problem ocurs it is changed to an enrmous value in the property sheet edit
Best regards
Thibaut
Message 6 of 8
(3,038 Views)
Hi Thibaut,
when you change the number of displayed coulmns/rows you naturally change the size (in pixel) of the indicator! You can't get one without the other...
Do you want to change the size of the data instead of the indicator? You know there's a difference between data and it's display on the frontpanel...
There are simple array functions in their own function palette!
Message 7 of 8
(3,036 Views)
the Pb is :
I only progmmatically modifiied   the nb of row of the matrix ( and not the the Nb of column)
It should increase the height of the control but not the width ...
It seems that I have only this problem  when the matrix is embedded in a cluster
regards
Thibaut
Message 8 of 8
(3,034 Views)
