real time pc validator
 hi all i cant seem to find the software for the pc validation for real time as specified in the tutorial http://www.ni.com/swf/presentation/us/labview/lvpctarget/
any help ?
thnx
Regards
Message 1 of 11
(5,290 Views)
Is this what you are looking for?
How Can I Test My PC for Compatibility with LabVIEW Real-Time or LabWindows/CVI Real-Time for Deskto...
Message Edited by Phillip Brooks on 05-29-2009 08:24 AM
Message 2 of 11
(5,270 Views)
Probably, but the links on that page seem to be broken currently...
Message 3 of 11
(5,266 Views)
the link is broken anyother options??
Regards
Message 4 of 11
(5,242 Views)
The link that Phillip gave is not broken and the attachments are there. Exactly what link are you trying to use?
Message 5 of 11
(5,235 Views)
The link to the eval tools (attachments) are broken, or at least they don't work for me.
For instance 8.5.1 eval tool (link from the KB article).
Message 6 of 11
(5,227 Views)
You're right. I did not attempt to download the zip files. They are hosted on the ae site which is only available to NI.
Message 7 of 11
(5,222 Views)
I submitted feedback on that KB article to point out the broken links. Hopefully NI sees it and will fix the link.
Yet another KB article with links to the internal site. Geez.
Message 8 of 11
(5,212 Views)
I searched Google using a set of keywords from one of the linked pages on the page I provided.
"Real-Time Module PC Evaluator"
I think this might be the file:
http://joule.ni.com/nidu/cds/view/p/id/882/lang/en
A search of the NI forums for "pceval.exe" indicates that this utility may not be reliable.  Smiley Sad
Message Edited by Phillip Brooks on 06-01-2009 12:03 PM
Message 9 of 11
(5,191 Views)
Hi All,
Thanks for pointing out this problem. We will work on getting this link fixed. The document that Phillip linked does have the tool, so you can use that in the meantime. When the KnowledgeBase article is edited, it may just link to that instead of attaching the tool anyway.
I will post here to let you know when that fix has been made in case you want to make sure that you can access the tool from that article.
Stephen S.
Applications Engineering
Message 10 of 11
(5,181 Views)
