real time output update from custom express vi
Hello to all
I have a question. Is it possible to update a express vi output on real time in a vi that uses it?
Inside the vi there is a while loop receiving constantly data, and it is stopped only when a certain button is pressed. I use local variables to update a YT chart outside that loop. The chart updates on real time as I pretend.
When I build the express vi, or even if I use the vi as a subvi, nothing happens, the output only updates when the subvi finishes. I will need to update a input on real time too.
I have tried with event structures also, they work, but only inside the vi, if I use it again as a subvi the problem persists.
I know that the output of a subvi only updates when it finishes, but I really need it to update on real time to be possible to use it as an express vi, to be implemented on any project.
Thanks for the help
(2,721 Views)
This should answer your question:
Updating a Control or Indicator of a Top Level VI from a SubVI
If it doesn't, please post a version of your code that highlights the issue and we can help you quicker.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,720 Views)
Ok it worked, the STOP button control is working now from the top vi.
Another question, is it possible to do this to a indicator. When I change the refnum to an indicator I can't connect it to the property node.
I want this subvi to be controlled by the STOP button and it´s output to be updated on real time in the top vi, until the STOP button is pressed.
I don´t know if it is possible to do, but I want this subvi to be easy to use, what I intend to say is that when someone create a control, let´s use the STOP button, I want it to connect directly to the subvi without creating references as I´m doing now. The same happens to the output.
(2,696 Views)
I forgot to mention, I can update the output on the main vi using a global variable, but as I mentioned before it´s not practical to use. The vi I´m building is a data acquisition vi and is intended to use much like the DAQ assistant from NI. So when I want to see the output it would be only necessary to create an indicator, the same happens to the stop button.
(2,670 Views)
