10-01-2009 12:48 AM
hi ...
I am tryin to convert a desktop pc to use labview real time .....but when i boot my pc using usb (desktop utility usb real time already created using MAX in usb) it give me the error "DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER"
any suggestions?
10-01-2009 12:53 AM
Hope this will give you a solution. Always remember to do a search in the forum. Most of the problems were solved. Post if you had still problems.
Mathan
10-01-2009 12:57 AM
hi ...thnx it was solved but now when i select the option "boot using software installled on the hard disk ......it gives me the error unable to configure primary network device ....
i have xp installed on the harddisk an labview 8.2 ...do i need to format the whole hard disk before convertng it to a real time target??
10-01-2009 01:07 AM
10-01-2009 01:07 AM
similary if i select the option "evaluate system" it gives the error
"system error kernel.446610 : LFS Error : Not a DOS disk: pc_dskinit "
10-01-2009 01:10 AM
nolsqn wrote:similary if i select the option "evaluate system" it gives the error
10-01-2009 01:15 AM
10-01-2009 02:08 AM
i have read the disscusions they all say that the ethernet drivers are not correctly installed ...i have installed them again they seem to be working ok in XP but when i run the evaluate test from the usb disk utility it gives only one error system state: IP stack Confriguration Error
10-01-2009 02:20 AM
Reinstalling the XP driver will not help in LV RT. LV RT has its own drivers, but only a limited set of ethernet chipsets is supported. See requirements document here.
By the way, what file system do you use? NTFS is not supported by LV RT. You will have to use FAT32. Again, check the requirements document.
Hope this helps,
Daniel
10-01-2009 02:38 AM
i just keep getting this " Broadcom 57xx Ethernet "... error ..it gets intialized but " no devices found " ..why is that ..???
Loading Ethernet Drivers:
Intel 8255x Ethernet initialized successfully
Intel 8254x Ethernet initialized successfully
Broadcom 57xx Ethernet initialized successfully
Finding devices for Ethernet drivers:
Error! No supported network devices found. A network adapter with
a supported Ethernet chipset is required
Starting up IP Stack.... failed.
Unable to configure the primary network device
System state: IP Stack Configuration Error
