real-time 9.0 startup delay
Starting with the real-time module for LabView 9.0 (2009) VIs deployed
to the RT target have a delay of up to 10 seconds before they are actually
executing.  This is quite annoying especially during development. Under LabView 8.6
I did not observe this issue. What could be causing this?
(3,429 Views)
What kind of target are you using? I'm using multiple cRIO with LV2009 and i didn't experience a delay compared to 8.6.
Do you have more details about the code? Is the delay after the code is deployed or before?
regards
Tobias
(3,413 Views)
My target is a PC running Interval Zeros ETS.
The delay occurs after deployment and only if the
VI was changed, e.g. redeployment without any
changes does not produce a delay.
I attached a minimal VI derived from one of the DAQmx
examples, which reproduces the delay.
The shared variable "recorded_data_io" uses a RT FIFO
for 1D double arrays containing 200 elements.
Best regards
Dominik
(3,406 Views)
I don't think that we're supporting ETS RT OS. Can you run your VIs there directly? I would recommend you to use our LabVIEW RT Operating System (based on Pharlab).
Tobias
(3,368 Views)
Well maybe this was a misunderstanding.
I'm talking about the RT OS shipped by National Instruments with
the RT Module 9.0.
The OS is still ETS formerly sold by Pharlap and now Interval Zero.
(3,356 Views)
The deployment delays are encountered by all the members of our working group.
So this is certainly not a specific hardware-related problem of the host/target computer.
Yet, we are all using Windows XP as the host OS. Did nobody else observe similar
delays in their RT setup?
(3,286 Views)
