05-01-2007 04:05 PM
05-01-2007 05:14 PM - edited 05-01-2007 05:14 PM
The name of the variable is RunState.Root.Locals.UUT.SerialNumber. When you create your VI, have a string control that you pass this in. This is done when do the Specify Module as shown below. Here's an example sequence and VI as well. You can also make it a bit more complicated by using the sequence context and the TestStand Get Property Value function.
Message Edited by Dennis Knutson on 05-01-2007 04:16 PM
