reading tdms file
I am unable to read the data of the attached tdms file image, cumulative hour column with same precision. The values what what i saved under this column is nothing but the data acquisition rate in a cumulative manner. i.e 0.0000138889 values corresponds to 50ms, second row value 0.0000277778 corresponds to 100ms. I am just saving millisecond value as Hour.
I am using standard tdms file viewer vi. And my labview version is 2017.
Hope some one help.
(3,169 Views)
Hi gkm,
@gkrn wrote:
I am unable to read the data of the attached tdms file image, cumulative hour column with same precision. … Hope some one help.
You would get far more help when you would attach that TDMS file (not just an image of the file content!).
It would also help to attach the VI where you write data to the TDMS file…
(Best would be to place the whole project with a TDMS example file in a ZIP file.)
(3,160 Views)
I am attaching the file...
(3,031 Views)
Accepted by topic author gkrn
Hi gkm,
thanks for the TDMS file.
This is (the start of) its content:
So you save that "millisecond value as Hour" and it is stored with unit hour. What is your problem?
Why are you unable to read the data, when the TDMSMonitor in LabVIEW can read the data?
Again: you should also attach the VI, where you generate that TDMS file, and you should attach your VI used for reading the data…
(3,015 Views)
Thanks for your time and reply.
(3,000 Views)
