reading matlab .m file
I think the problem was you were type casting to U16 instead of U32.  The Bytes consist of 8 bits and when you read four off into an array you get 32 bits.
Find the attached vi which i used to debug what was going on.  The Vi basically reads a line from the file (2x4 Bytes = 2* 32 bit words) which i scroll up and down the file table using the index which i have modified to a step size of 8 (8 Bytes)
Hope this helps.
Craig
LabVIEW 2012
Message 11 of 15
(1,677 Views)
Any Luck with this?  I take it you got it working OK
Craig
LabVIEW 2012
Message 12 of 15
(1,646 Views)
Yes, I got it.
Thanks for the help and sorry for the late answer.
crimolvic
Message 13 of 15
(1,570 Views)
i have some bearing data files in matlab (.m format). i want to read these files for analysis in labveiw.
Can any one help me how i can read these file????
Regards
Message 14 of 15
(1,134 Views)
Regards
Please do a search. This question has come up many times, and many suggestions have been provided. For example, http://zone.ni.com/devzone/cda/epd/p/id/4178
Message 15 of 15
(1,129 Views)
