reading from graph to text file in labview 7.0
Hi Guys!
I am doing a project which reads analog values from a microprocessor board and I am using the Labview example Cont Acq&Graph Voltage-Int Clk.vi. I am getting an analogue graph using this VI. is there any way I can convert the values on the graph and save them to a text file?
Any help would be much appreciated!
Pauline
Message 1 of 8
(4,201 Views)
Hi Pauline
There are several solutions, depending on the information you want to store in your txt-file.
An easy way is to use the "Export Waveform to Spreadsheet File.vi" (located in the palette int Waveform >> Waveform File I/O.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 8
(4,194 Views)
Thanks for your response!
How can I use the Export Waveform to Spreadsheet File.vi if I am already using the Cont Acq&Graph Voltage-Int Clk.vi to generate the waveforms. Is there a way of connecting the two VI's?
Pauline
Message 3 of 8
(4,185 Views)
Hi Pauline
There are two ways. Either you place the Export vi in the vi you're already using or you assign the waveform indicator to a terminal (search the LV help for terminal). This makes the waveform-data available for other vi's if you use the Cont...vi as a sub-vi. This means you can create a new vi, place the cont acq&graph valtage-int clk.vi and the export waveform to spreadsheet file.vi in it and wire these together (similar to all the vi's in con acq&graph...vi).
Thomas
Using LV8.0
Message 4 of 8
(4,180 Views)
How exactly do I connect the two VI's. I have never used labview before so i dont know where to start.
Can I just copy and paste the waveform vi? How do i then connect up the two vi's?
Message 5 of 8
(4,157 Views)
Hi Pauline
If you don't know how to connect vis, search in the LV help for this phrase: Wiring Block Diagram Objects Manually
Hope this helps.
Thomas
Using LV8.0
Message 6 of 8
(4,151 Views)
Hi Pauline,
The "Export Waveform to Spreadsheet File.vi" is probably the best way to write the data to a text file. I have made a simple example of this to show what to wire to the "Export Waveform to Spreadsheet File.vi" to get you started. I have done this by generating a sine wave, and writing the values to a text file.
Hope this helps,
Lilly
Message 7 of 8
(4,137 Views)
Hi Pauline,
I forgot to save the example back to version 7.0, so here is the version 7.0 one.
Regards
Lilly
National Instruments UK
Message 8 of 8
(4,134 Views)
