reading from XML file is too slow
I am trying to read some values from XML file, it takes about 1 or 2 minutes to finish reading, my xml file has about 4000 xml elements. Does anyone know this is normal or something wrong? How could make it faster?
Thank you
Message 1 of 10
(5,239 Views)
how do you access the xml file? using the labview xml tools, or do you use the ms xml parser?
i recommend use the xml parser using dom model and xpath-querys this should speed up the access to your xml file
have further questions feel free to ask
Message 2 of 10
(5,239 Views)
Hello Jun.z,
We will need a little more information on how you a reading the file to know why it is taking so long. One possibility may be in your file reading routine and not the XML parsing. Things like opening and closing a file every read can definitely slow down an application.
Please let us know how we can help.
Matt F
Message 3 of 10
(5,239 Views)
Thanks for your reply, the attached files are the vi and xml file, reading from xml file takes about 39s(sorry, not 1 or 2 minutes), xml elements processing loop take about 50ms. My xml file has about 2000 elements.
Thank you.
Message 4 of 10
(5,239 Views)
it seems that "read from xml-file" is somewhat slow.
in the attachment are two vi's.
the first one reads your xml-file in two 1D-Arrays (one for var-names the other one for the values, for use with "search 1D-Array") and in one 2D-Array.
the second one is a 'replacement' for "read from xml-file".
but i suggested that you use a spreadsheet-file, it make it somewhat easier to save and loads the vars.
Message 5 of 10
(5,239 Views)
Thank you. Could you please save the files in Labview 7.0 format? I can't open 7.1 files.
Message 6 of 10
(5,239 Views)
of course, here they are
Message 7 of 10
(5,239 Views)
It is much faster, thanks a lot.
Message 8 of 10
(5,239 Views)
Catweazle,
In your xmlFile_GetElements_(Array).vi the logic gate which controls the termination of the while loop needs to be AND rather than OR. As drawn it never stops.
Very nice improvement on the original.
Lynn
Message 9 of 10
(5,239 Views)
fine if it helps others... i hope NI will not be angry *fg*
thx for your bug-report, i do not test the sub.vi until now.
exchange the OR with an AND, solves the problem with the endless-loop, but error checking will not work (the loop only stops if no error AND no start-tag is found)
changing the loop termination condition and putting the NOT from the error condition to the no_starttag_flag do both. correctly stops the loop when error occurs OR no further elements found.
i attached the new sub.vi for version 7.0 and 7.1, also but some colors in the logo, for your convinience 😉
catweazle
Message 10 of 10
(5,239 Views)
