reading emails from gmail by labview
heartware wrote:
I do not have the same menu as yours. Is there other ways to unmark?
Where did you tried clicking on "Options" menu? Are you sure that you tried clicking on "Options" located at the top right corner of your post (15th post in this thread)?
Message 21 of 40
(3,900 Views)
Yes. That is what I used. Report to moderator is also grayed out.
Message 22 of 40
(3,890 Views)
 :smileysurprised: :smileysurprised: :smileysurprised: :smileysurprised: :smileysurprised:
Message 23 of 40
(3,882 Views)
This is not possible. Only when you logged out, the things in the options menu will get grayed out.
Message 24 of 40
(3,878 Views)
I think you would have logged in but not "signed in". Is that the case?
Message 25 of 40
(3,874 Views)
It would be the opposite i think. Sign in - for website logging, Log in - for forums login.?
Message 26 of 40
(3,874 Views)
Once I singed in I was able to select the options. Thanks
Message 27 of 40
(3,871 Views)
Thanks for taking time in marking the solution.......
This will definitely going to help lot of people in the future.....
Message Edited by Mathan on 09-14-2009 07:30 AM
Message 28 of 40
(3,868 Views)
Did anyone managed to get more than 250 messages downloaded from GMail?
The GetTotalMessageCount gives always 250 and GetMessage call gives an error if I try to a number out of the 1-250 range.
Is there somehow -- a trick I can't find -- a way to say that it has to get the next 250 messages?
Message 29 of 40
(3,534 Views)
Hello Harlequindae,
I was unable to verify the 250 GetTotalMessageCount restriction due to firewall restrictions here, but after doing a little digging on the C#Mail discussion form I found that someone has had a similar download number restriction that they ran into. With a little modification the user was able to download 300+ messages using the dll call. Perhaps, this post will shed a little more light on the situation: http://csharpmail.codeplex.com/discussions/230600 .
Best,
Blayne Kettlewell
Message 30 of 40
(3,519 Views)
