reading .dat files
I have a piece of hardware that logs data into a .dat file. The data is comma separated format. I need to read this data into LV. At the moment I can read the data into labview once I have converted the data into tab separated using MS Excel. But i dont want to do this every time. Is there a way that i can convert the data into tab format via labview OR is there a way of reading in the comma separated data?
Also another question i would like to ask is, can i simultaneously read the data from the .dat file while the logger is still writting to the file?
Cheers
Rhys
Message 1 of 13
(9,235 Views)
Hopefully you are using Read from Spreadsheet File.vi to get the data into LV.  Hidden under the Polymorphic selector is an input called delimiter.  One well-placed string constant later, you are reading comma delimited files now.
Message 2 of 13
(9,234 Views)
Ah yes i noticed that input. But what constant do I need to place onto it to read comma format?
Thanks for the reply!
Message 3 of 13
(9,229 Views)
do i simply place a , on the constant input?
Any ideas on reading and writting to the file the same time?
Message 4 of 13
(9,225 Views)
A string constant that contains a comma!
Message 5 of 13
(9,222 Views)
Cheers! i shall try in the morning when i get back to work.
Any ideas about reading and writting simultaneously?
Message 6 of 13
(9,215 Views)
Reading and Writing simulataneously while in LabVIEW?  You'd have issues with file pointers, and why would you want to do that?
Reading and writing simultanesouls with another application?  You'll probably have issues with the other application locking the file, or even LabVIEW locking the file while the other application wants to access it.
Message 7 of 13
(9,208 Views)
when the hardware records the live data to the .dat file, i would like to be able to display the data.
i have tried doing it before without much success. Just wanted to now if it was possible or not.
Message 8 of 13
(9,204 Views)
If you dont mind, please let me know how can I get data from a .dat file of 11bit binary samples of 1024 samples in LV waveform output....
Cheers!!
F Joe.
your response will be appreciated
Message 9 of 13
(8,955 Views)
This sounds like a different issue.  You should have started another thread.  Anyways...
What is writing the file?  I don't know of any systems that store data 11 bits at a time.  I would guess that the data is actually stored in 16 bits.  Do you have a document or anything about the data format?
Message 10 of 13
(8,953 Views)
