reading acceleration channel properties programatically
I am creating a virtual channel that is reading a TEDS compatible accelerometer. Prior to creating the channel I execute "DAQmx Configure TEDS" on the physical channel in order to read the TEDS information. What I can't figure out is how to find and read several of the accelerometer channel properties so I can verify the TEDS information is correct. Specifically, I cannot find properties for sensitivity, or sensitivity units. I looked in "DAQmx Channel" and "DAQmx Physical Channel" porperiy nodes but could not find sensitivity. Thanks for your help.
(2,636 Views)
I used to have the same problem. I spend a lot of time trying to find a property node or a VI in order to retrieve the information previously defined in the document, but unfortunately I wasn’t able to find one.
(2,575 Views)
