reading a file from excel
hello all ,
 pls give me a solution for this . i have tried to read a excel file using "read delimited spreadsheet " . its read everything as zero not the exact data . i have attached my files excel file and VI . Have a look at this .
(4,359 Views)
Look into this : All Zeros Returned when Reading an Excel File: http://digital.ni.com/public.nsf/allkb/0C2969C5673DCEF586257A080055F597
uday
(4,320 Views)
you don't use the good functions, you have to use the Excel function to read an Excel file.
I have attached a modified VI.
Regards
(4,317 Views)
This VI cannot read .xlsx files. Therefore, you have two alternatives:
The first one is to save your excel file under .txt format
for example save as Text (MS-DOS) (*.txt).
Be sure you have selected String as data type and change the indicator as well, since you have some strings in the first row.
The second alternative: I provide you a small program that will allow you to read Excel files (and .txt files) in LabVIEW.
Greetings and Regards,
James.
James
(4,310 Views)
