read xml file to table
Hi guys
I m trying to read a very big xml file to a table indicator in a labview
I had tried both read from xml.vi and read from spreadsheet.
Either of them gives me a lot of problem.
Can anyone of u help? I have also browse the example but in vain.
Can i have an example plss... very simple one...
Message 1 of 14
(6,772 Views)
Hi sean1985,
can you upload a short version of your xml file?
Mike
Message 2 of 14
(6,763 Views)
ermmm..  just left my workplace.
u can reference from the find example read from xml .vi . i had tried mine by using the technique learnt over there.
But my data to read from is a big xml consists of 100+ columns and rows.
however i just cant get it.
pls help
Message 3 of 14
(6,760 Views)
Hi sean1985,
here is an example, how you can create an xml string and read from it. I don´t write the string to a file or read from it, but this should be no problem.
Hope it helps.
Mike
Message 4 of 14
(6,740 Views)
but my xml is in terms of DBL format...
i have been having problem with the data type of the unflatten.. cos i dunno whether should i used a DBL format or an array format in terms of DBL.
i tried both.. it just dun link up..
why?
Message 5 of 14
(6,735 Views)
Hi sean1985,
i don´t know what you mean, if i change it to double instead of string it works in the same way.
Mike
Message 6 of 14
(6,726 Views)
The XML functions that are included with LabVIEW assume that you created the XML file using those functions. LabVIEW uses a specific XML format. If you have a generic XML file you will not be able to use these functions. You will need to use a third-party library, like LabXML or the EasyXML Toolkit.
Message 7 of 14
(6,716 Views)
this is my code. pls take a  look
i m wondering what is xml element?
flatten and unflatten all these stuff?
when i run. i got an error 1105 by the unflatten.vi
Message 8 of 14
(6,691 Views)
it written unknown or unexpected tag is discovered??
Message 9 of 14
(6,690 Views)
i had tried to use readfromspreadsheet.vi too. but nothing came out
basically my spreadsheet. ex. each row contains more than one number in each column
Message 10 of 14
(6,687 Views)
