read text files
Hello All,
I created a vi that will read text files from a specific path and display this data onto a wavechart. I was wondering is it possible to have my vi read specific lines from this text file instead of the whole text file? For example, if I wanted my vi to read only lines 27-31 from the text file and string this data onto a wavechart is it possible to do so? Thanks in advance
Message 1 of 8
(5,116 Views)
@Theopolis wrote:
Hello All,
Not really...
Just read it all into an array and use the array tools to select the lines you want from the array.
=== Engineer Ambiguously ===
Message 2 of 8
(5,110 Views)
Thanks man
Message 3 of 8
(5,103 Views)
@Theopolis wrote:
Thanks man
Thanks are given with Kudos and marking solutions.
Also if you want to read a file one line at a time you can right click the Read from Text File and select Read Lines.  You can read lines 23 by ignoring the first 22 lines.
Message 4 of 8
(5,075 Views)
I've gotten to that part, but then what if I don't want to read the lines after 26? What if I wanted to only read lines 23 - 26?
Message 5 of 8
(5,071 Views)
Message 6 of 8
(5,063 Views)
Hooovahh, no need for the loops...
Message 7 of 8
(5,045 Views)
That possibly explains it for me.
Message 8 of 8
(5,041 Views)
