read subvi variable
HI all,
I would like to keep reading some values inside a subvi. This subvi is a for loop with 100 iterations.
I mean, I want to read outside of this subvi each iteration but in the same loop.
Any idea?
Regards
Kito
(3,225 Views)
What exactly you are trying to achieve??
Numeric is an indicator as well as a variable.
Do you want to read numeric "indicator" to be read continously??
If that is the case, Use reference of the indicator.
Bijay
(3,196 Views)
Accepted by topic author Kitofelipe
You cannot do it in the same loop as the subVI, because the loop cannot proceed to the next iteration unless the subVI has completed. You need to use a seperate loop.
What is the purpose of this execise, just complicate things unecessary? 😮
(3,189 Views)
Thanks. I can read in a separete loop.
Regards
(3,168 Views)
