read serial port
If that works ok except for the last instruction I think you should add on the .txt file a \r at the end of your txt file.
As you are getting the data previous to the /r pattern match the last instruction is not read if you dont put the /r at the end.
Can you try that to see if that works?
Jaime Cabrera
NI Applications Engineering
Jaime Cabrera
NI Applications Engineering Spain
Message 11 of 12
(692 Views)
Hello. The program works thanks to your advice very well. Now i have another question. I want to read the answers of the robot, and i have made a while loop, like the example. The problem is that only works for one instruction, and stops. Do you know what is the problem. Thanks for all.
Message 12 of 12
(647 Views)
