read multiple DAQ data packet in one WHILE iteration
I am looking for a solution to the following problem :
I am using a PXI-6132 to acquire an anlogue waveform, the DAQ is trigerred by the falling edge of an other analog waveform with the same theoritical frequency. What I would like to do is to acquire for example 30 samples after the trigger, then store this data in the on-board memory; then wait for the next falling edge (my trigger) to acquire another 30 samples batch and, after let say 5 acquisition events, transfer this data form the on-board memory to my host computer memory to be read by a classical "Read fonction" in one itération of my while loop. I tried a lot of solutions (for ex. by setting the on-board memory buffer size to 150 before entering the while loop) but the read function still reads only 30 samples in one iteration. Is it possible to find a solution with the classical : create channel, timing function, trigerring function then a read function in a while loop or do I need to use a more complicated structure ....
Thanks in advance for your help
(2,419 Views)
Please post questions only once. This is a double post - see here
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(2,403 Views)
