read from text document
I would like to display the first(Greylevel) and third (Phaseshift) coloumn on a waveform graph. But I do not know how to connect it in the block diagram. And do i need to put in a property node for TimeStamp that displays ItemName and what does it do? I followed most of my diagram from the Read from Text file.vi.
Please kindly tell me if i need to put in any other function into the block to make it work.
Here's the text document:
(2,752 Views)
Duplicate Post
You should edit your original message, or add another message to the same thread when you add more information.  Starting a new thread just splits up the help people will be trying to give you.
Continue in the new thread that has the additional info.
(2,736 Views)
Oops sorry. I just started using this forum so I'm not used to it. I just posted a new one with all of the info as a new message. Please help me to take a look at it. Thanks!
(2,732 Views)
Hi LHX,
Ravens has clearly indicated what to do. with reference to some basic tutorials you can very easily implement it.
For your help, i have implemented as Ravens has indicated. I have connected a graph also but you can see that it is only plotting phaseshift(since Grey level is evenly distributed,the result is same). Refer to LabVIEW help for better understanding and use accoringly.
______________________________________________
Kudos are welcome
(2,704 Views)
