Hi mora,
no, I don't speak french. But maybe you can speak german? (Btw. I still prefer English, as nearly all other here on the forum can share as well.)
To save all those values I would suggest string formatting functions. Using 'Format to string' you can join all needed values to a well defined string. When this is done you can save the string to a text file. Use 'appending mode' (LV8+: set file position to EndOfFile) to build up a file for repetitive measurement.
So please try to find informations on: saving strings to file (LabView help and examples!), file formats like CSV (comma separated values, tab separation is also very convenient, you can find informations on this also in Excel)
Now I'm gone to weekend. On Monday I'll be back for more help
