08-08-2014 02:10 AM
Hello to everyone!
I want to read a spreadsheet file VI, wich contain many rows with this format:
0.475009,0.242797;
0.023044,0.522105;
0.735105,0.634358;
0.955100,0.982586;
etc..
The goal is to divide these rows into 2 array: the first one contains the left number:
0.475009
0.023044
0.735105
0.955100
while the right one contains the right number:
0.242797
0.522105
0.634358
0.982586
Someone can help me?
Thanks and
Best regards!
08-08-2014 02:15 AM
08-08-2014 02:42 AM
Hi GerdW.
The end of line delimiter is ;
with comma i separate two different measurements: the left numbers rapresent a current measure, while the right numbers a voltage measure.
I want to read my csv file, split the numbers into two different array, then plot the current and the voltage.
My start point is:
where all rows are like this:
i want to separate the left numbers and the right numbers into two array
Best regards
08-08-2014 02:49 AM - edited 08-08-2014 02:50 AM
Hi Davide,
1. You need to give the separator char between your numbers, not the EOL char: change your string constant from semicolon to comma!
2. From your description I still think the semicolon is useless as you (probably) have some real EOL chars in your text file (CR, LF, or combination of both)!
08-08-2014 03:03 AM
3. And you should change the type of the "Read from Spreadsheet File"- VI to Dbl, then it should ignore the semicolon and gives back the datatype you need.
08-08-2014 04:24 AM
Resolved!
Thanks a lot!
Best regards
08-08-2014 04:25 AM
