read from I60
I used to use "Read from I16" VI to read a binary file on Labview 7.1. Now, I'm using Labview 8.5 which has "Read from binary" VI. However, Read from binary VI doesn't have "start with read offset". Could you please teach me how I can take this in a newer version?
(4,635 Views)
Advanced File Functions: Set File Position.
Lynn
(4,631 Views)
Thanks, Lynn. But I got one more problem. Since the data type of my input is "path" but not "refnum" which is input for "Set file position" VI. I know there is a VI converting 'refnum to path', but I don't know how to do the other way around. Could you tell me how to do it?
Best,
Jay
(4,620 Views)
Accepted by topic author jeongho20000
Jay,
Use the open file function.  The Set File Position and Read from Binary File functions can be inside a loop if multiple reads will be performed.  (The image is from LV2009 but I think the functions are the same in 8.x).
Lynn
(4,611 Views)
Should I have "close file" VI?
Jay
(4,600 Views)
Jay,
It is always safe to close each reference which has been opened.  In some cases it is important to do so to prevent memory leaks.  LV can do a pretty good job of closing references on its own, but it is not clear when it does so and when it may not, so closing explicitly is preferable.
Lynn
(4,587 Views)
thank you so much Lynn
(4,580 Views)
