read digital line input
Hi all,
I have a stream of digital data coming into 1 line in USB-6501. I have configured 1 digital line input using the DAQ express. How do I able to read this stream of data in an array or table with the time interval?
Any help is appreciated. Thnaks.
(3,077 Views)
You can configure your DAQ Assistan to read N samples, where N is the amount of bits that you want to read, and save them into an array of booleans.
Regards.
Jaime Peña
National Instruments Mexico
Ingeniería de Aplicaciones
www.ni.com/soporte
(3,065 Views)
I have configure the DAQ assistant to N samples with the required number of samples and rate. I save them to a boolean array but i have an error. It say the source is 1-D array of digital waveform and the sink is 1-D array of boolean.
(3,053 Views)
Hi
Try the attached VI and let us know if that is what you were looking for
Regards
Freelance_LV
TestAutomation Consultant
(3,045 Views)
Hi Freelance LV,
I am using version 8.5, are u able downconvert it for me?
@Freelance LV wrote:
Hi
(3,041 Views)
Hi
Attached is a screenshot.
Regards
Freelance_LV
(3,027 Views)
It's irrelevant since you cannot set the 6501 to read N samples at a specific rate. Your only option is to use On Demand timing. Surely your DAQ Assistant is giving you an error.
(3,018 Views)
