read data from 2 excel sheets and write both into 1 excel sheet
Greetings.  Let me explain this a bit.  I am wondering what would be the best way to go about this.
I have 2 small Excel spreadsheets.  I want to be able to read the first 5 cells in the first row from each spreadsheet.
I then want to write the data from those 2 sheets into a third different spreadsheet starting in different columns.
I do not have the Excel Report set.  I was hoping to do this with active X, but I'm not sure if this can be done.
Thank you,
bob
(2,600 Views)
Hi RLemo,
yes it is possible. See this thread for more informations. There is also an example.
http://forums.ni.com/ni/board/message?board.id=170&message.id=329136&query.id=110669#M329136
Hope it helps.
Mike
(2,596 Views)
You should peruse the Excel thread for lots of examples.
(2,591 Views)
