read bool value from xml
Hi all :
I try to read Boolean value from xml file , please see attach file , all the time this error rise
I know that The XML tag describing the type of data does not match, how can I get Boolean value " 1" or "0 "
wisam
(3,610 Views)
You are not trying to read boolean.. you are trying to read a DBL.
To read a DBL you must first write a DBL to XML.
To read a boolean replace the DBL with a boolean
(3,591 Views)
thanks
(3,567 Views)
