read and average n data from text file
I acquire numeric data from the oscilloscope [reading a waveform] that is stored in one column in a text file.
I need to read in selectable amount of data points to average/plot them.
So basically I wanna have a text file with millions of data points but I wanna plot say only every 1000. data point. I have tried many things I found here on the forum but as I am new to LabView, none of them really worked.
Does anybody have a suggestion.
Thanks.
Message 1 of 15
(5,197 Views)
Have you tried reading in the data using the "Read from Spreadsheet File" function (from the file I/O palette)?
Once you have the data in an array it should be pretty straightforward to use the plethora of array functions to accomplish what you need.
Dan
Message 2 of 15
(5,177 Views)
Read in a thousand data points using the read file functions, average, then plot.  Repeat.
What things did you see and try, but did not work?
Message 3 of 15
(5,176 Views)
among others I have tried to build the VI below but somehow I cannot get to the desired solution because according to the indicators it always stops after the first loop.
Can you have a look please?
Thanks.
Message 4 of 15
(5,155 Views)
hi krivan,
 If your data file is a simple text with only one column of data,you can use a simple read text file vi ,configured to read lines and count as 1000(everytime) and use some string to integer functions and calculate the average/mean.
Thannks and regards,
srikrishnaNF
Srikrishna
Message 5 of 15
(5,150 Views)
I have changed the code I use read from spreadsheet but something is still wrong and cannot really figure out what...
Message 6 of 15
(5,145 Views)
hi ,
 can you please attach your data file?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 7 of 15
(5,140 Views)
hi,
the data file:
Message 8 of 15
(5,134 Views)
 sorry for the mistake..what i mean to attach the text file from which you are reading the values.
Thanks and regards,
srikrishnaNF
Srikrishna
Message 9 of 15
(5,132 Views)
Message 10 of 15
(5,131 Views)
