re-compiling service?
"Does NI or anyone else offer a service to compile Mac LabView programs into applications to run in Windows and Linux?"
(2,742 Views)
Usually, LabVIEW VIs run on all platforms no matter what system they were developed under. You just copy your files from your Macintosh to the computer running LabVIEW under Linux or Windows. However, stand-alone applications (compiled programs) are platform specific. Hope this helps. /Mikael
(2,742 Views)
Just a bit of clarification. All LabVIEW VIs are compiled. A standalone application is built from the compiled VIs. If you need a built application, I would contact an Alliance member company to see how much they would charge. It might be a little or it might be a lot if the original Windows VIs used a lot of platform specific functions, (i.e. ActiveX). Go to http://www.ni.com/alliance/ to find a list of Alliance members.
(2,742 Views)
