range of chart Y axis changes with autoscale disabled
Hi all,
I have a chart on interface for my application. I defined max and min value for both direction by property and disabled auto scale for both x and y.
Surprisingly, when the build runs, the range of Y changed. I didn't see how this happened, but my coworker screencopied it.
How could that happen? Has anyone seen this before?
Anne
(2,276 Views)
What are you feeding into your chart?  Do you see this same behavior when you feed a numeric constant into it?  Any screenshots you can provide will be helpful for figuring out what is going on.
Scott A
SSP Product Manager
(2,246 Views)
My guess is someone changed the range manually.
With a build, anyone can click on the chart and change the Y range.
I will disable it and nobody can change it.
Anne
(2,237 Views)
