This system is using a AT-MIO16E card and labview. I am performing single channel analog scans using the NI SCXI analog input example, modified to use the RMS and extract frequency examples. During static testing (ANy one input), the readings are fine. In one frame, the 1125 is polled 4x, and the 1100 is polled once. The scan for the 1100 module does an RMS and frequency extraction. In this frame, the result from the frequency is NAN and the RMS is 0 about 50% of the time. Individually, the modules acquire the data flawlessly (1 volt, 49.5kHz). The 1100 is is passed scan rate, buffers, scans. The signal acquired is a 50kHz square wave. I've tried scan rates from 150 to 250k. Any ideas on what could be causing this?
