radix point
In a old version of LV I was using point to represent the radix point. With 8.2.1 I need to represent it with the coma. Can I change this setup ?
Thx
(3,547 Views)
That depends on many things. Are you talking about numeric indicators on the front panel, numbers formatted as strings, etc.?
Is your computer configured for a country that uses comma as decimal seperator? If so, Look under front panel options and make sure "use localize decimal point" is checked.
Many formatting functions also give you a choice. There is even a formatting code you can use "%,;" or "%.;" to select the desired seperator and %; to switch back to the defaults. Can you give us a bit more details?
(3,539 Views)
hi altenbach,
You had right. It was the regional and language options my problem.
Anyhow, I would like to know where I can use the formatting code %,; and %.;
thanks
Paul
(3,511 Views)
These specifiers can be used whenever you are converting number to strings or viceversa using function that have a Format String input (e.g. Format Into String or Scan From String).
Paolo
(3,503 Views)
Here's an example:
Message Edited by altenbach on 07-10-2007 09:07 AM
(3,495 Views)
