"video signal storage and proccesing"
Dear Sir,
I want to connect a ccd camera to my pc.then I want to display film from ccd on monitor(by labview).
I want this control on my film:
-brightness
-save frame on harddisk
-rotate the film or frame
can I use of labview?
If I can,please help me.
faithfully yours
saba
(3,003 Views)
You sure can do all that but you'll need the following:
- An appropriate frame grabber to acquire the video signal (http://sine.ni.com/apps/we/nioc.vp?cid=1292〈=US)
- IMAQ Vision Software for LabVIEW to do the processing on the images (http://sine.ni.com/apps/we/nioc.vp?cid=2881〈=US)
Hope this helps!
Yusuf C.
Applications Engineering
(3,003 Views)
Hello yusuf
Thanks for your answer.
But,Can I use a pc video card and labview to provide that(connect a ccd to pc and display film on monitor and save that ...)?
With best regards
ramin
(3,003 Views)
There is no built in functionality in LabVIEW to acquire video from a regular pc video card.
Yusuf C.
(3,003 Views)
Hello
Can I use a object(in visual basic or windows)?
Thanks.
Ramin
(3,003 Views)
Hello Yusuf,
I have a PXI system with a PXI-1411 and IMAQ Vision and NI-IMAQ. I'm using this card to acquire the video signal from a DVD.I'll like to develop an application with LV able to check frame by frame if my received signal is arriving in good conditions.This application should be able to detect if there's some frozen picture effect or if the DVD unit shows are incorrect pictures. I have no idea how to launch this project and if it can be done. Could you give me some idea or tell me the link of somewhere to find this? By the way, I have a PXI-8176. Thank you very much.
(3,003 Views)
